NI TestStand
Regarding .dll file
How to create .dll file in NI teststand?
(2,821 Views)
When you say create a dll, what are you wanting to create it from?
TestStand can call .dll using the available adapters, but I'm not sure what you mean when you want to create one.
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(2,742 Views)
you need a compiler that can compile your code into a .dll.
if you're programming in C, NI CVI can compile to .dll
(2,691 Views)
