NI TestStand
Register UI Message Callback in VB.NET
Hi, is there anyone who has try to register UI Message Callback in .NET platform?
(4,254 Views)
Hi cronisis
you find an example for C# attached.
VB.NET should work similar.
Regards
DianaS
(4,125 Views)
Just to clarify. It is not recommended to use Engine.RegisterUIMessageCallback() from .NET. Instead you should either create an instance of the application manager or engine activex control on a form (a hidden one if you don't want a visible UI) and add a handler for the UIMessageEvent of the activex control.
Hope this helps,
-Doug
(4,096 Views)
