NI TestStand
Remote Debugging - OI
While building the EXE for the Fully Featured OI (LabVIEW), I enabled the Remote debugging option (Enable Debugging and Wait for Degugger to Launch). I tested running it some remote PC  and it is running good. I connected this remote EXE to my computer, everything is loaded and the Block diagram is visble, but I got a Error while running the EXE (attached as an Image). Is there any problem with then ActiveX when called Remotely ? Please tell me what should be done to make the remote debugging possible.
This happens to my customized OI also,
Thanksm
AshwiN,
(3,072 Views)
Are you using TS remote EXE server?
CLD
(2,945 Views)
