Hi Sahc,
There are a couple of steps you'll need to go through in order to get this to work.
If you haven't already, you'll need to make sure enable the DCOM
options for your remote system. For a detail description of this
process, check out
Setting up TestStand as a Server for Remote Execution on page 5-15 of the
TestStand Reference Manual. You can find a link to this from the Help menu in TestStand. Select the
Search the TestStand Bookshelf option. A link to the TestStand Reference Manual is in the fourth bullet point under New Users.
As far as configuring your Station Options on your base deployment,
there are a couple of options. You can either deploy a Full OI to the
system, which allows you to configure the station options, or you can
configure the remote execution station options on your development
machine within the sequence editor. The majority of Station Options are
saved to the
TestExec.ini file found in
<TestStand>\Cfg.
Once you configure the options on your development machine you can
simply move this TestExec.ini file over to your base deployment machine.
Hope this helps Sahc, have a good one!
Dan Weiland
	Dan Weiland
