NI TestStand
Remove Number of loops, number of passes etc. from xml report
I am looping on steps with a custom loop type via the loop option tab of the step. But I don't want the "number of loops, number of passes" etc. to appear in the report. I found a solution for the html-report on this board, is there a way to remove them from the xml report?
Greetings,
Swen
(3,260 Views)
hello swen,
you could insert ActiveX-steps, which remove the passed and failed numbers from the resultlist dynamically.
then they won't show up in the report. i attached a demo sequence.
regards,
robert h
NI germany
(3,223 Views)
