NI TestStand
Remove Sequence call from xml report using the stylesheet
I modified the TR6_Horizontal.xls stylesheet in order to remove the indentation and begin/end sequence texts. However, I still get the sequence calls so data is divided in different tables. It would be great if the stylesheet could filter out sequence calls. My knowledge about xls editing is very limited.
Right now, the only way I know to avoid this issue is not showing sequence calls (and its tests) on reports and repeat test steps on the mainsequence (which are enabled for the report) . Then you can use the normal stylesheet.
For me, the implementation of TestStand should be so that this could be achieved by setting the sequence call to "Disabled" and the test within as "Enabled (override sequence setting)" for Result Recording Option. But it is not.
Message 11 of 11
(341 Views)
