NI TestStand
Remove step info from TestStand report
Hello all,
I want to remove the step info or merge it into loop indices (highlighted in image), It increases the steps in report. Please help.
(1,393 Views)
If I understand the problem, disabling results recording option for this step should work for you. See https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/run-options-tab-step-propert...
Alternatively you can always try to tweak the result list.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,209 Views)
