NI TestStand
Remove windows depending on user privilege?
Is it possible to show/hide certain windows on the TestStand exec depending on the privilege of the user.
For example, it doesn't seem necessary for an Operator to have access to the Insertion Palette - even though it can't be used.
I'm guessing not - and that's probably why the TestStand Simple and Full OIs are provided - but I thought I'd ask anyway.
Ronnie
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
(3,290 Views)
You should only be giving your operators the UI(OI) and not the sequence editor.  Then nobody can see the palettes.  Consider the OI the runtime engine/version of TS.  Whereas the Seq Editor is the development environment.
Operators will still see the Insertion Palette but they can't edit the sequences from the Seq Editor.  There is a customizable sequence editor that I'm sure is able to show and hide palettes and windows based on User Privs.  However, you have to get a license for that.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,286 Views)
"There is a customizable sequence editor that I'm sure is able to show and hide palettes and windows based on User Privs.  However, you have to get a license for that."
Really? Do you know where it is?
(3,281 Views)
https://www.ni.com/en/shop/electronic-test-instrumentation/application-software-for-electronic-test-...
It costs more than the original license and basically it is used for someone that would design a development system for a bunch of test engineers.
Good luck,
jigg
CTA, CLA
testeract.com
(3,272 Views)
