NI TestStand
Removing StationGlobals from .Net
I am using the following piece of code to delete the Stationglobal variable in TestStand from .Net
try
myEngine.Globals.DeleteSubProperty("ATE_CURRENT", 0x2);
it's not throwing any exceptions and executed sucessfully ,but i can see the variable still exsists in the TestStand.
How can i remove the stationGloabals,Do i need to do some thing else?
Thanks in advance
Bharathi
(3,031 Views)
Accepted by topic author IVI
IVI -
Try calling Engine.CommitGlobalsToDisk(True) after you delete the StationGlobal in question. Please let me know the results.
Hope this helps.
Manooch H.
(3,029 Views)
Thanks it worked!!!!!!!
(3,025 Views)
