NI TestStand
Renaming custom data type
All,
Is it possible to rename a Custom Data Type (programatically or via a CallBack etc...)? Specifically, the container UUT. I want to call it something else for my program.
(3,206 Views)
To rename a custom data you must have all files with instances of that type open when you make the change, otherwise they will be considered to have a different type with the old name when they are next opened. Do you mean the UUT process model data type? I would recommend against changing that since you will make your custom version of the process model less compatible with the default version, especially since the end user/operator does not necessarily ever have to see the type name, so it's probably not worth the hassle in that case.
Hope this helps,
-Doug
(3,195 Views)
Accepted by topic author CarmineS
Thanks Doug, this helps.
(3,167 Views)
