NI TestStand
Reorder ResultList array “Swap in place array‘
I need to change the order of the ResultList at the end of the sequences
I need to  reorder of the ResultSet Array at the end of the sequences. Any way is fine (API TestStand, F (x) Statement). Any Idea?
(1,604 Views)
Accepted by topic author gantarone
I use this expression to reorder the model plugin configuration (move index 0 to the end of the Plugins array). You can replace the Plugins array with yours and play with the expression a bit.
Parameters.ModelPluginConfiguration.Plugins.SetPropertyObjectByOffset(GetNumElements(Parameters.ModelPluginConfiguration.Plugins), PropOption_InsertElement | PropOption_NotOwning, Parameters.ModelPluginConfiguration.Plugins[Parameters.ModelPlugin.Base.RuntimeVariables.ProcessorIndex]),
Parameters.ModelPluginConfiguration.Plugins.DeleteElements(Parameters.ModelPlugin.Base.RuntimeVariables.ProcessorIndex, 1)
So something like this:
<AnArray>.SetPropertyObjectByOffset(
   <NewIndex>,
   <AnArray>[<CurrentIndex>] 'New Value
<AnArray>.DeleteElements(
   <CurrentIndex>,
   1
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,564 Views)
I apologize for the delay, I had found another solution, but this is simpler and therefore functional !!!
Thanks Bravo!!!
(1,537 Views)
