NI TestStand
Repeating a failed step when using labview adaptor
Hi all,
I'm trying to allow a user to retry a step when failed. Here's my approach:
  1. A step that uses a labview adaptor fails (step.result.passfail)
  2. Using the call back "SequenceFilePositStepFailure" I perform a message popup that asks the user if they want to retry the step. On the post-Expression for the popup i do the following:
    step.Result.ButtonHit == 1 ? (RunState.Caller.NextStepIndex = RunState.Caller.StepIndex) : (RunState.Caller.NextStepIndex = RunState.Caller.NextStepIndex),
    step.Result.ButtonHit == 1 ? (FileGlobals.Retry = True) : ( FileGlobals.Retry = False)
  3. Using the call back "SequenceFilePostResultListEntry" I do two steps that do the following in their Post-Expression:
    1. Parameters.DiscardResult = (Parameters.Result.Status == "Failed" && FileGlobals.Retry == True)
    2. FileGlobals.Retry = False
The above works absolutely fine if I use a step with no adaptor, but as soon as I use a labivew adaptor I get errors saying that the Step ID cannot be found. On investigation, the step ID doesn't exist anywhere in my sequence.
Where am I going wrong, how can I repeat a failed test using a labview adaptor without it appearing in my report that it failed if it passes on the retry?
(2,625 Views)
This is strange because I've replicated your sequence as you've described above and it works for No Adaptor and LabView Adaptor(!)
Can you post your sequence file and we'll have a look.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(2,608 Views)
Hi Charlie,
I found the issue, my labview steps were set to go to an invalid step on failure.
(2,598 Views)
No problem - glad I could help.
(2,586 Views)
