NI TestStand
Report Alignment
      I have one test of type "Numeric Limit Test". In Text Report file i will get Measurement, Units, Limit (Low and High), Comparision Type each in a seperate line. Is there is any possible to get all in a single line.
       Better if i get Measurement, Units, Limit (Low and High) in a single line.
Thanks.
Siva.
(3,530 Views)
(3,506 Views)
Siva,
There are a few options you should take into consideration before you change your report layout.  Report Options are configurable from the Configure -> Report Options menu in the TestStand Sequence Editor.  If you are building XML reports, then this will not be a trivial task because XML reports are based upon XSL stylesheets.  These require a pretty good knowledge of XML and XSL directives before changing the stylesheet format.  If you are using HTML or TXT reports, then this task becomes less difficult.
You can also determine how reports are generated.  Reports are built in a DLL or Sequence, depending on your confguration in the Report Options dialog.  The DLL calls a function in the ModelSupport2.dll.  This is a CVI project that you can edit and recompile for your own needs.  The project can be found in the <TestStand>/Components/NI/Models/TestStandModels directory.  Make sure that any changes you make to this file are saved in the corresponding <TestStand>/Components/User/Models/ directory, so that you don't overwrite the original dll.  The other option is to call a Sequence that builds a Report.  There are 3 sequence files that are also found in the <TestStandModels> directory.  They are called ReportGen_HTML.seq, ReportGen_TXT.seq, and ReportGen_XML.seq.  You can edit these sequences to change how your reports are generated.
The DLL function call or Sequence call is implemented from the TestReports sequence in the Process Model.  One or the other function call is made based on the parameter you set in the Report Options dialog.
The NumericLimitsTest step type includes variables that are built into the report (if they are configured to do so from the Report Options).  For instance, the Numeric Limits or Comp (comparison string) are included in the Report.  You can go to the Type Pallette, and take a look at the NumericLimitTest step type.  If you right click on the Comp variable and choose Properties... -> Advanced Properties, then you will see advanced properties that can be set for a variable.  The Comp is set to IncludeInReport by default.  This tells the Report Generation to include this value in the report.  Normally these values are built into a table (for HTML) or include line feeds in between them (for TXT).  You can change how these reports are generated by looking at the above mentioned sequence calls.
The final option you have, is to post process the Report that is generated by each UUT.  Again, by looking at the TestReport sequence, the final call in the Sequence is a Statement called Concatenate Report Header, Body, and Footer.  This builds a string which is used to build the entire report.  You can always build a code module to edit this string and remove key linefeeds or tables that are produced.
If you have any specific questions on any of this information, please post them here.
Good Luck!
Tyler Tigue
(3,488 Views)
