NI TestStand
Report Generation
Please take a look at the attached VI (LV6.1 attached a snapshot for others) and help me retrieve the measured value of each step from ResultList array. I need to extract other details like limits (low and high) test description, pass/fail from the sequence context as well after all the steps have been executed.
I am new to TestStand and trying to work my way through it using hit and trial.
Also please let me know where (Main/Cleanup/Callback/Custom) best can I have this step in the program(sequence).
Sumit Rishi
(3,690 Views)
hi sumitrishi,
I am guessing you are passing the complete ResultList array to your VI.
You have already obtain a reference to the Parameters so therefore any lookup string will not require "Parameters" as part of the makeup.
You do know that there is a supplied sequencefile, "reportgen_txt.seq" or "reportgen_html.seq", that performs this sort of actions already?
Regards
Ray Farmer
Regards
Ray Farmer
(3,675 Views)
Yes I do. But I wanted to use both of them together . people have been looking into HTML reports and are comforatble using them but for an automated system that extracts date from these reports in txt/csv format I need to generate them in text format as well. I wasnt sure if I could do them together.Please help clearifying my doubt.
Sumit
(3,669 Views)
A small change ( well maybe a smallish change) to your Process Model sequence file and you can make two calls to do both style of reports.
Regards
Ray Farmer
Regards
Ray Farmer
(3,662 Views)
