NI TestStand
Report Options Parameter access through Labview
Hi all,
I'm stuck inside the report options that i need to create a soft GUI which need to populate the parameters in the report options. I there any way to access the parameters in Report Options using property nodes. A hand of Help will be Appreciated...
A BIG THANKS IN ADVANCE
(1,231 Views)
In general you should be able to access the parameters in Report Options using property nodes, what version of software do you use?
(1,075 Views)
