NI TestStand
Report Options: Result Filtering Expression disabled
It seems I am unable to enable the following item under the Report Options menu item.
    Result Filtering Expression is disabled and always set to All.
Even with the tutorial example, Computer.seq, as described in Chapter 10 of the pdf Using Test Stand, I am unable to modify the control to select Exclude/Passed/Done/Skipped. Same problem with a brand new sequence file.
Am I missing something??
(3,699 Views)
Have you got the Report Format set to XML Document.
Its disabled for this option
Regards
Ray Farmer
Regards
Ray Farmer
(3,695 Views)
Thanks that was it.
Any reason why this feature is not available under XML??
(3,691 Views)
