NI TestStand
Report Options Specify Report File By Expression
Using TestStand 12; how do I set the report file path via a fileglobal variable within the sequence? I can set a static filepath by using the Report Options: 'Specify Report File By Expression' that seems to work, but what do I need to put in there for a variable filepath?
My guess is to use the ReportOptions Callback somehow but am unsure how; anyone managed to do this?
(3,248 Views)
Override ReportOptions callback, have a look on following article.
http://digital.ni.com/public.nsf/allkb/8ECD6E9D95F786338625729D0073451A
(3,212 Views)
That article is old and is not relevant for TestStand 12, so is not of much use.
(3,166 Views)
