NI TestStand
Report Time
Good Morning,
I think that is a simple problem but I can’t find the way to solve it: How can I add the timestamp (or the time at which the step is started) of each step to the report? In particular I want the time without being related to the start of Teststand Engine.
Is it possible to configure this option from the ModelPluginConfiguration or in some other sequence?
How can I set the time format as hours : minutes : seconds.microseconds?
Thank you for your answer and help!
Best Regards!
(1,792 Views)
Hi @miclab,
Have you tried steps described here: Solved: Add timestamp to report for each test step - NI Community
Best,
Rina
(1,674 Views)
