NI TestStand
Report View with On the Fly reporting
Any idea how to display the Complete report in the report view of customize OI when “On the fly reporting is enabled”?
 At the end of test (sequence) execution I am sending the UIMsg_DisplayReport and my OI has display report callback, but I think that is not enough.
The report view only displays the last section of the report.
Thanks in advance,
Vidula
(4,192 Views)
Under report options, disable the "Conserve memory and display only latest results" check box. That option would give the behavior that you're seeing.
Why do geeks think Halloween and Christmas occur on the same day?
Because 31oct = 25dec!
(4,171 Views)
I am looking for another alternative.
I do want my "Conserve memory and display only latest results" option checked.
My report is pretty big so I do not want that in memory during execution, but at the end of exection when all the modules are unloaded, I want to load the entire report in Report View.
(4,168 Views)
Vidula,
I was unable to reproduce this behavior. I ran the Computer Motherboard Demo using the Sequential Model with all combinations of options and did not get a different report. Are you using a custom process model that makes a custom report?
Steven Zittrower
http://www.ni.com/support
(4,159 Views)
Yes, I am using the custom process model and custom report format. My process model is based on Sequential Model and Report format is html.
I do not see the issue if the report is very small. If the report is big then only the portion of the report is getting displayed.
Message Edited by Vidula S. on 09-17-2009 10:01 AM
(4,157 Views)
From what I can tell, the sequecne file has to have multiple sequence calls before it purges old report data. To display the whole report. I had to close the execution, then open the actual report file, not the temp file.
(4,154 Views)
ExecutionView Manager control -> CaptionSource_ReportLocation–(Value: 28) gives the report file name at the end of execution when the report generation is complete.
I need the temp report file name and the final report name during execution.
Is there a way to get the report filename during the execution?
(4,150 Views)
