NI TestStand
Report empty
I'm not receiving the DisplayReport Event and
after receiving the EndExecution Event the Execution.Report is empty. What could be wrong?
I'm using C# .Net 2005 and TestStand 3.5
(3,819 Views)
Are running a sequence using the process model entry point, eg Test UUTs or Single Pass?
Regards
Ray Farmer
Regards
Ray Farmer
(3,813 Views)
It's a good question. I'm starting Execution as following:
applicationMgr.GetEngine().NewExecution(sequenceFile,sequenceName,null,false,0,null,null,null);
(3,793 Views)
Seeing you have the third parameters as a NULL, this means you are not using the Process Model entry points therefore you will not have a report generated.
If you need a report, then you will need to pass a reference to the process model sequence file in the third parameter and in the second parameter you need to pass a string containing the name of the Entry Point eg "Test UUTs" or "Single Pass".
I hope this helps.
Regards
Ray Farmer
Regards
Ray Farmer
(3,790 Views)
Thanks a lot, that was it.
(3,784 Views)
