NI TestStand
Report generation enabled without showing the report
I'm new to TestStand and I have just created my first large application in TestStand 3.5 (and LabVIEW 8.5.1)
Now I have a question regarding the report generation.
I'm running the sequence editor and report generation is enabled.
Each time when I stop the measurement (instead of scanning a new barcode I select quit) the execution terminates and a report is shown.
Is there a way to prevent this report from being displayed. I only want the report to be logged to disc, not shown to the user.
Thanks for the help!
John
(3,555 Views)
you can try "RunState.Root.Locals.ReportOptions.DisableReportGeneration"
Regards
Ray Farmer
Regards
Ray Farmer
(3,550 Views)
Isn't that the same as completely disabling the report generation?
I just want the report not to be displayed to the user.
The report file must still be logged to disc but I don't want the operator to see it.
(3,535 Views)
John,
You will need to modify the Process model to include a statement step at the end of the Cleanup section that executes the following command.
RunState.Thread.PostUIMessageEx(UIMsg_CloseWindows,0,"",RunState.Execution,True)
This command will allow the report to be written disk, but will not be displayed to the user.
-Adri K.
Adri Kruger
LabVIEW Product Marketing
(3,499 Views)
You might beable to just use the ProcessCleanup callback and therefore do not need to modify the Process Model.
Regards
Ray Farmer
Regards
Ray Farmer
(3,486 Views)
