NI TestStand
Report generation:sepecify by expression take long time from PreUUT to MainSquence
I set TestStand Report File direcory type as "SpecificByExpression",such as"\"d:\\\\TestStand Report\\<UUTStatus>\\\\<UUT>_[<FileTime>][<FileDate>]_<UUTStatus>.<FileExtension>\,"
When TestStand runs,after "PreUUT" ,it takes up to 3-4s to get to "MainSequence".
When I set direcoty type to "Specific Directory",it is OK.
So is there a way to improve this?Thanks
(4,339 Views)
Not sure, but your expression looks wrong. It should be something more like the following:
"d:\\TestStand Report\\<UUTStatus>\\<UUT>_[<FileTime>][<FileDate>]_<UUTStatus>.<FileExtension>"
Perhaps this is somehow indirectly causing a problem?
-Doug
(4,325 Views)
I am using parallel model,and the prompt that TestStand shows as below
My expression can work properly,before I also used your expressions and found it can not work.
(4,321 Views)
Oh you are setting the expression with an expression, then you do need another set of quotes and additional backslash escaping. Nevermind.
Have you tried debugging the sequence and/or process to see what code it is in that is taking so long to execute?
-Doug
(4,310 Views)
