NI TestStand
Report is not displayed in xml format.
We have a test station based in teststand 4.1 and labview 8.6 code modules.
From one day to another, the xml report is blank, no character is displayed. That in Operator interface or sequence file execution in teststand editor.If the report format is changed to ASCII or HTML, then runs OK.
The first step taken was to reload the directories "Cfg\*.ini" and "teststandmodels\Stylesheets\*.xls" from another test station that runs ok. Not solved.
The second option was to uninstall and reinstall teststand. Also not solved the problem. Then I suposse that this problem is caused for a file or parameter that is not dependent of Teststand, but I don't really know.
Any suggestions would be appreciated.
Bergidum.
(3,588 Views)
Hi Bierzo,
Is it something that happened in all your tests or just in one? for example, execute the example "Computer motherboard test" using XLM reporting options on and let me know the result.
In addition, did you try the on-the-fly reporting option?
Did you try different Stylesheet options?
The report options are configured in the model so, try to execute the example "computer motherboard" using a different Model (batch or parallel)
(3,579 Views)
Thanks for your help Sendia,
Yes, I have already tried Computer mother test and all type of reporting options. Only ASCII and and HTML report formats generate visible results.
Also on-the-fly-reporting is my option by default.
Before format and reinstall the operating system (windows XP) and reinstall the NI package, I would like to know the origin of the malfunction because there are other five test stations working properly, but if the same problem appears in a new station, then to know the solution.
Thanks for your attention,
Bierzo.
(3,574 Views)
What about the different stylesheet options and different models?
(3,572 Views)
Sorry I forgot to respond stylesheet.
Also malfunction with expand, report and horizontal. I tried to copy this files from other station running OK, but not the solution.
The message in the report display when XML report format is selected is:
"Unable to process the XML Report with the specified style sheet"
About different models I don't know it in report options.
Bierzo.
(3,569 Views)
What is a process Model?
Change the actual Sequential Model (use the Motherboard example) by other like Batch Model and test the report generation
(3,566 Views)
