NI TestStand
Report showing measurements in table (wanted) AND in-line (unwanted)
I've got a sequence that gives me a report like this, but I don't want the extra in-line information.  How can I remove it?
We have a custom report options interface where, if I turn off "Include Measurements", I can get rid of the extra stuff but I lose the measured values in the table.  The architect on the team that developed the architecture I'm using said he's never seen this! 🤦‍♂️Is there a TestStand setting that is generating this?  Maybe it's in the style sheet?  I don't know where to look.
Thank you,
Jim
Jim
(546 Views)
I guess I'd go for the style sheet...
(519 Views)
I initially suspected the same thing, but I need to remove content and not just change the style.  It seems the answer would lie in some TestStand configuration, either at a station level or even individual steps.
Jim
(512 Views)
You can certainly modify the stylesheet to avoid these showing these results. Another approach is to set the "Don't Copy to Results" flag for any property that you do not want to show in the report. Note this will impact what results are collected for the step. So, it will impact anything that processes results including Database loggers etc.
Anand Jain
NI
(433 Views)
