NI TestStand
Report
I need to make dynamically created paths for my reports.
I've tried to add the reportoptions callback, and two statements, one for setting the report path and one for setting generate path to false. Is this the correct way to handle specific report path for each sequence and each UUT.
I have handled this so far via the "configure report" options pane, but it get messy when deploying those settings to different type of teststations. I need to be able to handle this specifically in each sequence i make, to be absolutely sure what happens.
however i don't get any reports. My simple test seq is attached.
Is it possible to add the PASS/FAIL status to the filename. i.e. to change the filename after the seq has either passed or failed ?
Message 11 of 19
(1,805 Views)
I think the information you are looking for is in this white paper, specifically the part in section 5 about specifying report file paths by expression. You should be able to change your path based off if the UUT passed or failed.
https://www.linkedin.com/in/trentweaver
Message 12 of 19
(1,786 Views)
Hi WireWeaver
Thanks for the link to the white paper. I've read it but i'm still having some problems.
I've made a simple sequence containing 1 step. I have put in the reportOptions callback and added the expression shown in the first attachment.
At Runtime the parameter "ReportFileSequentialModelExpression" turns RED, and the quotes around the expression are gone !
I get a report file in the correct folder, but it has no name, only extension .xml
what have I done wrong here ?
Is there a document describing all the reportOptions parameters.  They are not all selfexplanatory.
Some of them are even string types, but works like enums.... or am I wrong ?
my seq is attached
Message 13 of 19
(1,770 Views)
Hey Nikolaj,
I would try "\"$(UUT)_Report.$(FileExtension)\""
You need to insert the quotations into the equation. Check out this article: http://zone.ni.com/reference/en-XX/help/370052J-01/tssuppref/infotopics/special_string_characters/
Michael Bilyk
Former NI Software Engineer (IT)
Message 14 of 19
(1,753 Views)
That's right. Now the string is encapsulated in quotes.
However I still only get a report named ".xml"  i.e only extenstion, and no name...
Message 15 of 19
(1,735 Views)
Since $(UUT) is supposed to replace the macro with the UUT serial number, is there a chance you are executing via Single Pass?  Or not entering a serial number name in the UUT pop-up when executing via "Test UUTs?"  In both these cases there would be no serial number to replace the macro.
Michael Keane
Message 16 of 19
(1,707 Views)
unfortunately not.
I'm executing via F5-press (Test UUTs) in the development tool.
The serial number is shown in the report.
It seems as the macro is not interpreted at all.
Message 17 of 19
(1,697 Views)
Are any of the other macros working such as the ones described in this link?
Specifying Report File Paths by Expression
http://zone.ni.com/reference/en-XX/help/370052K-01/tsref/infotopics/specifyreportfilepath_byexpressi...
Michael Keane
Message 18 of 19
(1,677 Views)
Message 19 of 19
(1,618 Views)
