NI TestStand
Reports ASCII Text - Removing multiple headers, indents and Line Feeds
Hello All,
I am trying to steamline my Teststand generated ASCIII Report text file. Is there a way to do the following without touching the the reporting models (sequence) files?
1. Remove indents
2. Remove line feeds inbetween lines
3. Remove repeated instances of the following and just have one instance at the top.
ID    Test Name     Type     Low  Lim     Meas     Upp Lim Unit    Result     Time[s]
Minesh
(4,295 Views)
Minesh,
To achieve this, you will need to do some customized reporting and formatting.
This white paper goes over the best practices for report generation customization. It even has a walkthrough of removing indents.
There is plenty of other documentation available that can assist you in customizing your report.
Steven Gloor
Staff Customer Engineer - CTA, CLD
(4,271 Views)
