NI TestStand
Requirements Gateway and Doors Types
No Requirements Gateway board but am working with TestStand also..
I am pulling requirements from DOORS and I need to filter out a column but I cannot find a way to check that a column is NOT empty. I already made a DOORS advanced type and I am trying to edit the requirement field to filter out a column called Interface Name. I want to only pull in the rows where Interface Name is populated. I am currently pulling in useless information where the column is empty. I tried leaving the value blank and negating it to mimic a 'not empty' concept and that did not work. Any suggestions?
(4,770 Views)
Hey cframe,
You should be able to do this by specifying that the object should have an attribute of a certain name. For example, this is the DOORS module for the basic DOORS example we provide with Requirements Gateway:
And here is an example of how you could configure the Requirement field to only pull requirements which have a Priority specified:
By specifying that each requirement must have an Attribute with the name "Priority", you are configuring the type to only recognize requirements which have a Priority defined.
I hope this helps, and please let me know if you run into any trouble with it--I'd be happy to help further if this doesn't solve it.
(4,737 Views)
