NI TestStand
Requirements Gateway and PDFs
I can't find a group for the Requirements Gateway tool, but I did find a post saying members in this group may be able to help, so here goes....
I am trying to use requirements gateway (2018 version on evaluation licence only at the moment) to help with traceability for my requirements.  I have some information (e.g. in suppliers data sheets) that I want to add a trace to (e.g. as a source for a requirement).
I can not get requirements gateway to recognise sticky notes in the pdf.  As far as I can tell I should be able to add sticky notes to the pdf and then as long as I select the "with annotations" option in the pdf type then requirements gateway should recognise the stick notes and be able to use them to identify traces.
I have tried looking at the intermediate files and can see that there is no entries in that which correspond to any annotations that I add to a pdf, so I think the problem is with the "PdfCv Txt" conversion tool which creates the intermediate file, but I am not sure.
I am sure I have had this working before (in a previous life) so I am wondering if there is a NIRG/PDF compatibility issue with the versions I am using.
Any help would be appreciated.
Andy
(1,022 Views)
Hi  AndyMac01
Did you check THIS forum post? Try to go through that solution it can be helpful in this case.
Regards)
(922 Views)
