NI TestStand
Reseting Flie Global Vaiables
Is there a way to reset all File Global variables to their default values in Teststand without having to modify them one by one?
(1,235 Views)
Default values are here: https://zone.ni.com/reference/en-XX/help/370052AA-01/tsapiref/reftopics/sequencefile_fileglobalsdefa...
You should be able to replace your current globals with those from this prop.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,209 Views)
You may need to use Clone() method.
Michał Bieńkowski
CLA, CTA, CPI
(1,201 Views)
