NI TestStand
Result Processing - Additional results work only when any of the "Output Name" Enabled
Only if i   ENABLE  any result type  only then the SequenceFilePostResultListEntry    is called
the thing is I have aditional results & I save them in TDM format
hence I dont need  the options from the   Result processing
is this  functional behaviour  expected from   teststand
(4,832 Views)
Hello aparab,
can you please explain it a little bit for me,
or modify the attached TS 2013 Sequence to show what you mean?
Thanks a lot
best regards
Alexander
(4,546 Views)
Hallo Alexander,
I want to convey that only when  the option in Result Processing  is enabled then   only I get  the Sequencefile post resultlistentry callback activated.
(4,537 Views)
Hello aparab,
i have greated a StationGlobals ReportActivated and fill this global in the callback
ReportOptions with the the flag, if the report generation is disabled or not.
In the SequenceFilePostResultListEntry a if structure is insert that ckecks the flag.
Hope this helps.
best regards
Alexander
(4,526 Views)
