NI TestStand
Result Processing Dialog Box
I've installed TS2014 SP1 f1 on an ATE using an Evaluation license.  I want to configure report options but when I select Configure from the TS menu there is no option to select Result Processing.  How do I make TS show this configuration option?
BTW, I am logged into TS as Admin.
Thx.
(2,803 Views)
Hi chino_boy,
I tried to do the same with my TS 2017 in evaluation mode and I do get the Result Processing option even in evaluation mode.
I would recommend:
i) Downloading new TS 2014 SP1 evaluation files: http://www.ni.com/download/ni-teststand-development-system-2014-sp1/5541/en/
ii) Replacing the license files: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8UUSA0
iii) Opening a Service Request with an Application Engineer if this doesn´t work.
(2,766 Views)
The Result Processing option magically re-appeared for no apparent reason.  I've no idea why it disappeared or why it returned.  But thanks for your response.
(2,756 Views)
