NI TestStand
Result reporting entries missing
I'm having an issue with my results file.  If I run the teststand sequence on the development Pc it works fine but when I deploy the code and run it on a  deployment PC the html fail summary only shows the first fail.
e.g.
4.1 Test x fails
4.2 Test y fails
The fail summary only shows the first fail.
My suspicion is that there is something in the public folder that is altering the html reporting mechanism.  I removed reportgen_html from the directory:
C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.2.1\Components\Models\TestStandModels
but the problem still persists.  Does anyone know what could be causing the failure?
Sean
(3,075 Views)
Accepted by topic author SeanJ
The problem was actually the reportgen_html.seq file as I had first guessed.
The deployment tool was pulling the an older version of reportgen_html.seq.
The headache is over.
(3,067 Views)
