NI TestStand
Return a column from the elements in an array of containers
Some background...I have a custom type called XYZ, which is a container which contains three numbers (X, Y, Z). From this I have an array of type XYZ. I want to return all "Y" values for use as a Data Source in a NumericLimit test.
I know with a regular 2D array I can do this to return a column of data...
Locals.SingleColumn = Locals.Array2D[0..][1]
With an array of containers I was expecting to be able to do something like this, but it throws an error (I think something like "unknown property Y")...
Locals.SingleColumn = Locals.ArrayXYZ[0..].Y
 I've tried using the API and I can get pretty close, but it returns an array of object references instead of an array of numbers which is what I'm really looking for...
Locals.SingleColumn = Locals.ArrayXYZ.GetSubProperties("Y", 0)
So how do I generate an array of numbers from one of the element fields within this array of containers??
Message 1 of 1
(1,084 Views)
