NI TestStand
Run TestStand Sequence Silently in C# with Report
I'm using TestStand 2012 SP1 and Visual Studio 2010.
I want to run a TestStand sequence silently in my C# software.
I saw on this web site how to do to run a TestStand sequence (https://decibel.ni.com/content/docs/DOC-29585).
This example is really interresting to know how to run it using the .NET interop API.
The problem I can't solve is that no report is created when running the sequence although I added a step to setup the ReportOptions.
You will found here, the class I use to start the TestStand sequence :
public Execution StartSequence(string sequenceFilename, string resultDir, out SequenceFile seqFile)
            Execution exec = null;
            try
                User admin = Engine.GetUser("administrator");
                Engine.CurrentUser = admin;
                SequenceFile seqFileModel = null;
                StationOptions stationOptions = Engine.StationOptions;
                stationOptions.DisableResults = false;
                stationOptions.AllowOtherModels = true;
                int flags = 107; // GetSeqFileOptions.GetSeqFile_OperatorInterfaceFlags;
                seqFile = Engine.GetSequenceFileEx(sequenceFilename, flags, TypeConflictHandlerTypes.ConflictHandler_Prompt);
                bool modelExists;
                string modelPath = seqFile.GetModelAbsolutePath(out modelExists);
                seqFileModel = Engine.GetSequenceFileEx(modelPath, GetSeqFileOptions.GetSeqFile_NoOptions, TypeConflictHandlerTypes.ConflictHandler_Prompt);
                // Setup the report options
                int reportOptionCallbackIndex = seqFile.GetSequenceIndex(DefaultModelCallbacks.DefModCback_ReportOptions);
                if (reportOptionCallbackIndex > -1)
                    seqFile.DeleteSequence(reportOptionCallbackIndex);
                Sequence reportGenCallback = seqFile.CreateCallbackOverrideSequence(DefaultModelCallbacks.DefModCback_ReportOptions, false);
                InsertStatementStep(reportGenCallback,
                    "Parameters.ReportOptions.DisableReportGeneration=False,\n" +
                    "Parameters.ReportOptions.GeneratePath=False,\n" +
                    string.Format("Parameters.ReportOptions.ReportFilePath=\"{0}\",\n", GenerateReportFilename(resultDir, sequenceFilename)) +
                    "Parameters.ReportOptions.UseOnTheFlyReporting=True,\n" +
                    "Parameters.ReportOptions.PurgeOnTheFlyResults=True");
                exec = Engine.NewExecution(seqFile, "Single Pass", seqFileModel, false, 0, null, null, null);
                exec.Report.Location = resultDir;
            catch (Exception)
                throw;
            return exec;
What's wrong with my code and what should I do to get a report associated to the single pass ?
I hope someone will help me
Best Regards,
CFOE
(6,623 Views)
The process model creates the report. Does the Engine.NewExecution( ... seqFileModel...) call refer to a valid process model? Does your sequence file have a model option specified in the sequence file properties?
cc
(6,585 Views)
as far I could see while debugging, the process model associated to the sequence file is the SequentialModel and as far as I know, the SequentialModel can create a report.
I get the sequence file model using the command seqFile.GetModelAbsolutePath.
Best Regards,
CFOE
(6,578 Views)
Accepted by topic author cfoe
This code works fine I just forgot to manage the Execution messages by polling.
Best Regards,
CFOE
(6,552 Views)
