NI TestStand
Run-Time Error window doesn't have Retry and Ignore options
The run-Time Error window usually have 4 bullets at the bottom part.  They all used to be enabled untill recently.  Somehow, I only have the Run Cleanup and Abort immediately bullets enabled.  Why are the Retry and Ignore disabled?  Is there an option to turn it on and off?
Rafi
(3,438 Views)
Its possible you have operator privileges. What's user type are you running as?
Regards
Ray Farmer
Regards
Ray Farmer
(3,425 Views)
The enabled/disabled state of the Retry and Ignore radio buttons in the Run-Time Error dialog are controlled by the Debug>>ControlExecFlow privilege in the User Manager.
(3,064 Views)
