NI TestStand
Run a TestStand sequence with CVI
I am trying to open a TestStand sequence (*.seq) with a small C application, but I'm a beginner and I have some problems.
So i start with theses functions:
TS_NewEngine
TS_EngineGetSeqFileEx
TS_SeqFileGetProperty        ( not sure that i really need that...)
And so I don't know which functions I need to continue and launch the sequence. I tried TS_EngineNewExecution but its not working...Can someone help me for this problem?
Thank,  Romain
(3,582 Views)
Hi Romain
I think the best would be to open CVI source-codes of the UI-Interface
It is shipped with TS.
You will find it under <ProgramFolder>\National Instruments\TestStand X.Y\UserInterfaces\NI\Simple\CVI
Hint: Before modifiying copy it to the folder parent folder<user>
Greetings
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,578 Views)
try this example as a guide, it's and early Teststand example (1.0.1) so I wouldn't expect it to work straight from the box, unless of course you are using TS1.0.1.
Regards
Ray Farmer
Regards
Ray Farmer
(3,571 Views)
Thank you Ray,
for pointing this link.
This is better because there is no UI-stuff.
juergen
--Signature--
(3,568 Views)
Thank you Ray Farmer! It was exactely what I needed and my program works now.
Regards
Roro
(3,561 Views)
