NI TestStand
Run an entire sequence from the sequence call step
Under the sequence call I have the input parameters for File Pathname and Sequence. For the sequence I would like to run the entire thing rather than just one of the sequences that are available. How can I do this?
(3,800 Views)
Hi Steve,
Just for understanding, with "entire" you are thinking of all the sequences from a specific SequenceFile
which contains no Callbacks.
Is that right?
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,790 Views)
I want to run all sequences, including the callbacks. Normally I would run the tsetexec for each test from a shortcut, but I was tasked to run everything from a single sequence.
(3,762 Views)
Hi Steve
To run all the stuff you could use ProcessModel.
In your SequnceCall StepType there are Execution Options
Select "Use New Execution" now you can select an Entry Point.
In the advanced Options you can select time Wait conditons
Hope this helps
Juergen
--Signature--
(3,760 Views)
The problem is that when I do it that way and select an entry point, it only runs the entry point and then returns from it.
(3,758 Views)
Hi Steve,
have you entered the name of the sequnce in the Parameter Field ?
juergen
--Signature--
(3,754 Views)
