NI TestStand
Run cmd.exe in 32-bit version of TS as if it was run in 64-bit version
I try to call this Bluetooth on/off PowerShell script using the CallExecutable step in TestStand 2020 32-bit. Apparently, it fails in step $bluetooth = $radios | ? { $_.Kind -eq 'Bluetooth' }. However, if I switch to TestStand 2020 64-bit it works like a charm. How can I force the 32-bit version of TestStand to run the CallExecutable step in 64-bit mode? Or maybe how to force cmd.exe/PowerShell.exe in this step to run in 64-bit mode?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,105 Views)
Accepted by topic author bienieck
My solution is to use bat file. This bat is called using CallExecutable step in TestStand 2020 32-bit. In this bat I call ps1 file BUT using 64 bit PowerShell. Like this: %SystemRoot%\sysnative\WindowsPowerShell\v1.0\PowerShell.exe -NoProfile -ExecutionPolicy Bypass -File %ScriptPath%
Michał Bieńkowski
CLA, CTA, CPI
(2,070 Views)
There is even easier solution, without bat file:
Michał Bieńkowski
CLA, CTA, CPI
(2,020 Views)
