NI TestStand
Run mode = skip to a specific module in multiple sequences
My goal is to skip a specific module that is used in multiple sequences. I am looking for a method that easily finds a module in each of my tests in Main.
(2,666 Views)
Can you give us more information about why you are trying to skip a specific module? Why wouldn't you just remove it from the sequences if you don't want it to run?
My initial thought would be to set a previous code module to have a Post Action to "On Pass" or "On Fail" to skip the code module in question.
But more information on what you are trying to do and why will be helpful. There may be a different way to architecture the sequences that make more sense.
Best,
Spencer R | NI
(2,631 Views)
