NI TestStand
Run multiple sequences concurrently
Thanks Doug,
Yes, it seems to be working correctly with a lock name now.  I can't hold the lock around multiple steps (although I'd like to so no need to modify each step) due to different step types inside the sequence file. The other step types call other unrelated code modules, so I don't think a lock is required.
I wonder if I need to put a lock on the default Wait. Thus far, it's working fine without it.
ph
Message 11 of 12
(1,118 Views)
Thanks Doug.
I think it's working fine now as I put the lock name on my steps.  I removed the lock from Wait steps as you mentioned before the steps that come with TestStand doesn't require locks.
ph2
Message 12 of 12
(1,109 Views)
