NI TestStand
Run sequence with base deployment engine
I have a  basic Teststand 4.2.1 sequence file that takes some data measuremts and records the results to a file. This sequence runs fine onthe development system and now I want to deploy this to some other deployment workstations.  I can run the deployment utiility and create an installation package. The deployment installes on the deployment workstations and I can configure the teststand base deployment engine license.
When I try to run my deployed sequence file, it always tries to run the full development version of teststand.  Since only the deployment version is licensed, I get stuck at prompt for the temporary 7 day evaluation. If I remove the teststand development evaluation licence, the sequect fails to run saying there is no license available.
How do I set my sequence to run under the base deployment engine license.  I don't have any fancy custom interfaces.  I just want the default teststand interface to run the sequence file in read only, no editing mode.
(3,695 Views)
Hi glsimpson,
You won't be able to use TestStand Sequence Editor to run your sequences.  You can use one of our pre-built UIs that installs with TestStand.  Please see Chapter 14 of the TestStand reference manual.  This has several examples of Deploying TestStand system.  Also you can take a look here for more information on TestStand licensing.
Cheers,
(3,671 Views)
