NI TestStand
Run-time Error Handling
I am having some difficulty finding information on the recommended way to
handle run-time errors, branching on errors, and setting the step error properties
when the step calls (for example) an ActiveX module. I have looked through
the TestStand manual and searched the knowledgebase but I have not found
any specifics.
I understand from a PDF document titled, "A Guide to Developing Effective,
Maintainable TestStand Sequences", that I am supposed to do the error-handling
in the area. The document says, "...it is a good idea to use the
Setup step group to contain your initialization steps and the Cleanup step
group to contain your error-handling and shutdown routines."
I also looked at rtebeep.seq in the ./Examples/RuntimeE
rrors/ directory.
It was a good example of how TestStand jumps to the cleanup group.
How do you keep the cleanup that needs to be performed on the instruments
separate from the error-handling routine? Or a related question, once you
are in the Cleanup group, how do you determine if you landed there because
of an error, or because the sequence is terminating normally?
I have tried using Gotos and Labels in the cleanup, which not only I can't
make work, but they are really ugly.
What happens if an error happens when execution is in the Cleanup step group?
I want to be able to handle those also.
I am fairly new to TestStand, slightly confused, and probably just need a
good example to work from. Can someone please point me to an example of
how to handle run-time errors. Any help or suggestions will be greatly appreciated.
(3,906 Views)
In the Step Type Properties, The Post Actions Tab has a selection for "On Fail"
I use this to point to a separate sub sequence for handling errors. And use the clean up for shutingdown or reseting instruments.
Hope this helps
Rob Kennedy
rkennedy@cpesys.com.au
(3,906 Views)
