NI TestStand
Run-time error not shown in ResultList
I try to log run-time errors using a custom data logging VI in the Cleanup stage of the sequence. I caused a run-time error, which is clearly shown in the execution window but I do not see it in the ResultList. Where can I obtain the error message then? Please refer to the attached images.
I appreciate any input.
(4,463 Views)
I found some examples showing a couple of different ways to handle errors in Teststand. I think these examples will give you a good idea on how to configure your test sequence. The readme file attached to each example is also very helpful.
Link: http://www.ni.com/example/27719/en/
James F.
(4,399 Views)
Thanks for the reply. I already took a look at the website in the meantime. I found that the error (Code, Msg & Occurred) is logged at the sequence call level while the error container for the particular step which caused the error does not hold any information. However, I need to indicate which step within the subsequence caused the error. Is there any simple way to do this?
(4,395 Views)
I found that the error I created was rather a special case. I used a wrong variable name in the Additional Results tab to cause an error. When I tried causing an error in the precondition or limits, the error was properly saved to the step's error container.
(4,377 Views)
Ahh. Glad you were able to figure it out!
James F.
(4,363 Views)
