NI TestStand
RunState.Report.Append function
I noticed that.  I fixed it.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 11 of 13
(620 Views)
~jiggawax~ FYI,
Although your code to reformat the Report works...
Turn out the easiest solution is to modify the horizontal.xsl file. No need to include sequence calls if your formatting is no indentation. Start by making a backup copy of the horizontal.xsl (javascript) file. Edit the file by changing "var gIndentationWidth = 40;" from 40 to 0. Save the file, done.
Reports still kinda ugly since the Seq header is separate from the result tables.
TestStand Help instructions sent me changing "gIndentTables" and looking for a boolean setting from True to False... these instruction were either out dated or wrong.
Message 12 of 13
(609 Views)
So I'm curious to know how you fixed that, what changed? Cus I'm looking at my code at my desk that doesn't report sequence calls vs the TS in the lab here that does report sequence calls...
Message 13 of 13
(607 Views)
