NI TestStand
RunTine Error occurs after using customer report style sheet
I use a new style sheet "expend_QA" to customize test report.
Spoiler
But when I start running sequence, the error occurs and I have no idea what is it meaning.
What's the "ReportAdvData" ??? I can't find it in variable column.
(2,221 Views)
If you switch back to just the expand.xsl style sheet do you still get the error?  It looks like something has changed in one of your sequence files.  The stylesheet is simply applied at the end to the XML and shouldn't have any impact on execution....that I'm aware of.
Can you pause it on the Get Report Header step and do a search for ReportAdvData and take a screenshot of where it takes you?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,193 Views)
