NI TestStand
Running 2 vi's parallelly
Hi All,
I am a new user to Test Stand. I have to call LabVIEW files through Test Stand Application. I have to call a VI, which has a start button. To this start button I am passing TRUE value which will invoke another VI. Now I have to pass values to the VI which is invoked at run time.
In another test step I have accessed this VI with values given to those inputs. But the problem is the control is not returned back from the first step.
Here the First VI should be in Running State. The invoked VI should get inputs from the test stand. After invokind the first VI the control should come to execute next Test Step. So please help me how to achieve this in Test Stand?
Nagaraju.
Nagaraju
(2,986 Views)
http://forums.ni.com/ni/board/message?board.id=330&message.id=12954#M12954
the above link should help you
Regards
Ray Farmer
Regards
Ray Farmer
(2,979 Views)
