NI TestStand
Running an asynchronous LabView vi with Teststand makes the message pop-ups close automatically
I am calling a LabView vi asynchronously very early on in my test. Throughout the test I use "set" and "get" type vi's to retrieve and feed information to this vi but when I try to perform error checking and call a message pop-up, the pop-up closes right away as if the the first button is automatically being pushed. This behaviour exists only while the Asynch vi is up and running, the pop-ups operate correctly when the vi is not present. By correctly I mean they wait for user input...anyone have a clue why this is happening?
(3,010 Views)
What labview and teststand versions are you using, and is it possible to post and example.
Regards
Ray Farmer
Regards
Ray Farmer
(2,999 Views)
