NI TestStand
Running multiple sequence on NI TestSatnd
Hi
I am working on a task in which i need to run two sequence simultaneously, one to run the DUT and other to acquire the data both triggered at the same time. I am begginer to the NI teststand.
Is there a way to trigger both the sequence at the same time?
Thanks.
(2,893 Views)
I threw together a little example that demonstrates this.  Let me know if you have questions.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,868 Views)
Hi Jigg,
Many thanks for your example. The system i am working has Test Stand version 2013f1 (5.1.0240). Can you resend the same file for this compatible version?
Thanks!
(2,852 Views)
Enjoy
jigg
CTA, CLA
testeract.com
(2,833 Views)
Hi Jigg,
This example works!!, Thank you
(2,825 Views)
