Hi Hiren,
This dialog usually appears when you have two applications that have opened and modified the stationglobals.ini, such as having the operator interface and the SeqEditor open at the same time.
If you could answer a few questions it might help to pin point the problem
What TestStand version are you using?
Are you using the default Operator Interface?
In your StationGlobals.ini file read only, or have restricted access from your network administrator?
Briefly, what is your sequencefile performing before the dialog appears.
Do you have any other applications open that have opened the StationGlobals.ini?
Regards
Ray Farmer
Regards
Ray Farmer
