NI TestStand
Running teststand sequence on RT target?
Is there any (officially supported) way to run a TestStand sequence on Real Time target, like on an RT controller? (assuming that the the steps are compatible with the RT system (eg: no dll calls))? Pls note that my question in NOT to check if TestStand (running on a windows PC) can execute VIs on the RT target, but if sequences are supported on the RT?
I guess the answer is simply a no, but its worth checking.
Thanks.
(2,981 Views)
Accepted by topic author 1984
No, and TestStand probably never will. The TestStand Engine is deeply coupled to Microsoft technology, so the closest you can get is calling code on remote machines that are the OS of choice, but the sequencer is still on Windows.
- Regards,
Beutlich
(2,950 Views)
Thats what I thought... thanks for the confirmation!
(2,943 Views)
